Castle mamba x & sensored motor issues
le varan
france
hi guys,
Writing for a friend who doesn't speak english ! :lmao:
He's got a combo MAMBA X, 25.2V WP ESC AND 1406-3800KV SENSORED COMBO - Product #: 010-0155-11 for is RR10
running whitout the sensored cable works great ! But when the cable is one and setup with the castle usb link the motor cogs (don't know if it's the write word to describe : motor doesn't turn, tries to, but can, like if you were holding the shaft) when you strike the trigger.
Tried different settings :
  • inverting cable on the ESC, same problem going backwards
  • inverting the setting in the softwre, same problem going backwards
As anyone had the same issue ? :roll:
thanks
LV :flipoff:
Call castle theyre pretty good for customer service
hi guys,
thanks
LV :flipoff:
Sent from my LG-M703 using Tapatalk
Normally when it does that it mean the motor wires are not hooked up A-A, B-B, and C-C. Check this immediately. We get a lot of returns from people hooking the wires up incorrectly and causing the ESC to stop working.
And if yea do it with the sensor plugged in youll smoke the motor if the wires r wrong
I've passed on the information, I'm waiting for his feedback
Envoyé de mon SM-G930F en utilisant Tapatalk
Works great with the cables in the correct order !
Thanks to you all !
LV
