crawlinwithacat
Howdy folks, I've got a ponderable about servos. First some background: I've got a pair of Savox 1230sg's on a sporty comp rig that seem to be pretty weak recently. Both are being run off a CCBEC (the original one) and a 3s batt. They are rated for 500oz/in @6.0v. I've got the BEC set around 6.6v to account for the ~0.1v output voltage discrepancy and the rest for a little extra juice just because. I've been running them for the better part of 3 years now. That whole time I was running the BEC at 6.2v. I was messing with it this morning and thought I would try bumping up the voltage a bit to see if it did anything and the result was not much. I did just upgrade to 2.2s so they are definitely struggling a bit more than with the 1.9s but even with the 1.9s I was beginning to notice them struggling more than usual.
So anyway, my two thoughts have been 'Do BECs loose output current or develop internal resistances over time?' and 'Do servos weaken over time?'. Though I realized that the BEC being the issue was a pretty unreasonable conclusion the more I thought about it. So I did some research and came across two threads with some plane guys talking about something similar and the two potential culprits they mentioned were the potentiometer and the motor. The potentiometer sounded like it was the cause of centering issues. They were saying that in the past, it was possible to take the pot apart and clean the contacts because the wiper would wear down the middle of the contact and decrease it's sensitivity. Not really my problem, though wouldn't hurt to spray some contact cleaner in there. The other thing was the motors wear out over time. The commutators get dirty and the brushes wear down over time, which creates more resistance and leads to a weaker motor. Makes sense, but it is interesting that my front servo seems weaker than the rear. The front servo has been in use for probably 6-8 months longer because 4ws was an afterthought. Seems like things are pointing to the motors. But I'm curious, has anyone else noticed a similar phenomenon? Or does anyone have any other insights into what might be causing this? Cheers!
