I built an enduro! …….. well before this pandemic was really even a thing. The plan was to if’s swap it and use the proline metric body to build a sweet overland rig…. However after a year of not really going anywhere the idea was scrapped.
Then I went on shrink rc and saw they sold body mounts to mount an rc4wd xtra cab and knew what the build was going to be! Now I’m not much of a yota person but I like all of the opening parts.
Now onto the build! Currently the chassis is just a boring builders kit with an ifs conversion, however for this build it is actually going to go back to solid axle as I plan to build it for c1 without the interior. I don’t plan to comp it though it will be built so it won’t need much to be able to.
The plan is to use a roc412 3100kv with a mamba x esc and the non overdrive gears in the transmission. The axles will be getting ssd diff covers and link mounts, with the front also getting ssd chubs and brass knuckles with scx10ii axle shafts. For driveshafts it will be running the incision versions. Also will be running the bowhouse skid and ssd shock towers
Now for wheels in tires I’m going to use 1.55 ssd d hole wheels with pitbull growlers. Also forgot to mention that I’m running traxxas 5525 rod ends on one side of each rear link to extend the wheelbase enough for the body.
Now onto the pics
As you can see in the pics I did have to cut holes in the bed unfortunately. I was planning on going cantilever in the rear but with the way the bed mounts in the back, that idea was scrapped.
Now onto the pics
