Bully 2, tekin+ fxr+ picture help!!!
Meir
israel
My new accessories for my bully.
I need help please how to connect the dual's fxr to the dual's engines with the Cc Bec.
I try to read some article's and it doesnt works and i cant find any way.
Somone have an article or a picture?
Sent from my LG-H815 using Tapatalk
You have to bridge the fxr together. The b+ with the b+ and b-with the b- than pull out the red wire of the esc plug that goes into the receiver from both of the esc's put the CC bec in to the b+ and b- in one of the esc and of course your battery cable in that same esc the M+ and M- are for the motors
But its dual's fxr with dual's 55t tekin.
I think you may need to be more clear about what you are struggling with. I'll be doing this in a couple days but with the red wire coming out of the battery it needs to be routed through the b+ on each FXR and the black cable routed through the b- on each FXR. The BEC needs to be attached to those same two wires. red -> red, black -> black.
The diagram posted in the thread I linked is pretty clear so without more info it's going to be hard to see what is causing you issues. Perhaps you can define what you mean by it doesn't work. Post some pictures of what has failed.
First of all thanks!
Maybe u have a real picture? Like this picture, but something that i can see in clear please?
This is where I'm at right now. I plan to put a bit of electrical tape where the solder is.
Wowww greatttt!!!
Thanks matoch!!!
And where the two cabels in the side goes?
Wowww greatttt!!!
Thanks matoch!!!
The two thick cables are my power cables. I may change my mind but I'm planning on putting a battery on the front axle and another one on the rear axle.
The empty posts are where I'll hook up each motor. The rest is either switches or leads that go to the receiver.
First of thanks a lot its looks great i will be strating tonight.
But if i want one battery only how is it going?
The 2 last wires on the left side that run out of the picture, you wouldn't run those if running one battery. The 2 wires running out of the picture on the right side is what would hook up to battery.
Also, I hope your smashing them? Meaning decase both esc and put together then wire it and heat shrink together. If you look it up, you should find pictures of them smashed together to get the idea.
Its not to late to sell those tekins and get a holmes dual smashed escs. He can solder a bec on for you too. Then solder your motors and your ready!
Im starting to regret that i bought them and not smashed holmes hobbies!
Starting wish me luck [emoji41]
If its possible i would love to picture from the process.
Thank u so much!!!
You won't see much now that it's mounted. The only thing that's changed since the photo I showed you is that the motors are attached.
The advice I'd give you is give some though to your wire management and make sure you have the slack to allow the suspension to travel.
