I brought my first Summit in January of 2010 and the past five years with it have been a blast! I drove it stock for about 6 months, then put a Mamba Monster/2200kv brushless system in it. I drove it that way for another 6 months or so until the diffs blew up. I rebuild the diffs, put the brushless system in a proper 1/8th scale monster truck and went back to brushed. I had just gotten into FPV around this time and wanted to go back to brushed to make a smooth FPV rig out of it. In addition to replacing the brushless system, I ripped out the stock radio system and put in a 9 channel Turnigy system running DragonLink and a 1.2ghz video transmitter and pan/tilt control on the camera. It's a ton of fun, especially in the winter when it's too cold to stand outside and control an RC.
While I've been having a lot of fun with my FPV Summit I really began to miss having a stock Summit for when I just wanted to go bash around and not worry about ruining a ton of electronic equipment. I already have a few "go super-fast" 1/8th scalers, a comp-level AX-10 crawler and a couple SCX10's for scaling duties, so I don't need something to be a fast basher or a super-slow crawler. What I'm really after is a super, ultra reliable trail truck that can do a bit of everything and NEVER break down. The Summit in its stock form is almost perfect for this!
I debated for months whether I should buy another Summit for non-FPV duties and finally decided to go ahead and do it. It was a lot of money to spend and I was worried about buyer's remorse since I already have one Summit. I can tell you, I have absolutely no regrets about increasing the size of my Summit stable!
As I said, this Summit is going to stay mostly stock - most all of the upgrades that I make will be to enhance its durability and reliability rather than increase its performance. The goal is to be BULLETPROOF!
I've only made a few performance-related upgrades. The first was the addition of a Holmes Hobbies BRXL WP ESC. Compared to the EVX-2 (or ANY other brushed ESC) it's absolute butter! Being able to set throttle curves and ramp up/down power through Castle Link really changes the behavior of the truck and the low speed control is SICK! Oh, and drag brake on a Summit is great! The second performance-related upgrade was to ditch the stock rear springs for Traxxas double-orange springs. I run the truck with these springs front & rear with no pre-load. The truck sits with the driveshafts just above level and it performs SO much better than stock. The last performance-related upgrades I made were to gear down with an 11t pinion for better low-speed control and the addition of the Traxxas roof light bar for better night-time playing.
Now on the durability upgrades!
From my experiences with my first Summit I learned that the drivetrain is the weakest link on a Summit. I began by loosing the slipper clutch 1/4 turn out from stock (about 1 & 1/4 to 1 & 1/2 turns out from full spring compression). I am hoping to find a setting soft enough to keep the driveshafts from warping and breaking, but not so loose that I burn up the clutch. So far, this seems to be the optimal setting. After 1 month of hard, almost daily runs of 1 to 1.5 hours my driveshafts look brand new with no warping or distortion around the CVDs. FWIW, I had MIP axles on my other Summit and couldn't get them off fast enough. They are NOT a durability upgrade! In the future I am hoping to run a set of LEM aluminium axles once they're available.
Next up were the diffs. I purchased a set of LEM aluminium diff cups with hardened gears. I assembled these and shimmed them up so there's no play or binding in the diffs or diff cases. I removed the stock diff oil and repacked the diff and all diff bearings with Bel-Ray waterproof grease. Finally, I filled the bulkheads with hot glue after putting the diffs back in to keep dirt out and keep free-play/slop to a minimum.
Next up in the driveline was the transmission. I hate all the slop it has and I think, given enough time, this slop will cause wear on the tranny. Now to be honest, I've NEVER heard or read about anyone having issues with a Summit transmission, but why take chances? I installed a LEM aluminium dog carrier in the tranny and the difference is night and day!!! The transmission drops into low/high gear immediately and there's almost no slop! Very worthwhile upgrade!
The final driveline upgrade to was take out all the stock wheel bearings, open them up, pack them in waterproof grease and re-install.
To ensure no ESC problems I also installed a 10amp Castle BEC unit set to 6.0 volts. The truck itself runs off of 2 4s 4500mah batteries wired in parallel. This gives me 9000mah of 4s power, enough to give me 1.5 - 2 hours of runtime on a charge. The Holmes ESC runs on anything from 2s to 6s, so I also keep a small 1500mah 3s battery in my pocket when I'm on the trail. This gives me about 15-20 min to get back home without having to carry my truck back.
Topping off the durability upgrades are a set of T-Bone racing bumpers and skids, Outwears motor and chassis covers and stock Canyon tires that have been sealed with RTV silicon to make them waterproof.
And that's it! Like I said before, this truck will stay on 4s, running the Titan 775. When LEM releases their aluminum axles I'll pop on a set and call it good. My goal is to never have to stop this truck for a repair, only for planned maintainence and cleaning. The only failure points I see left are servos, arms and maybe a worn driveshaft or two after some time. I've got spares of all these on my bench ready to go.
Thoughts and feedback welcomed, especially any weak points I may have missed in this build.
Here's a quick summary and links to everything in case you want to check it out yourself!
Vehicle:
- Traxxas Summit 1/10
Performance Upgrades:
- BR-XL WP ESC
- Double Orange springs in rear
- 11/68 gearing
- Traxxas roof light bar
Durability Upgrades:
- LEM Aluminum Diff Cups and hardened gears
- LEM Dog Carrier in transmission
- All wheel and diff bearings packed with Bel-Ray Waterproof Grease
- Castle BEC
- 2x 4S 4500mah in parallel
- T-Bone Racing skids and bumpers
- Outwears motor cover
- Outwears chassis cover
- RTV silicon sealed Trxxas Canyon AT tires
And now pictures!
Here it is with the stock shell painted olive drab:
And with its new shell in Tamiya PS-19 Camel Yellow:
Vehicle:
- BR-XL WP ESC
- 11/68 gearing
- Castle BEC
And now pictures!
