Builder's Notes: SCX24 Micro Shark Conversion Kit
TheBakedBeans
Chicago Area
SCX24 Micro Shark Conversion Kit Designed by Mod19 and built by TheBakedBeans
Build Video
https://youtu.be/ilLGJ5vLn6s
SCX24 Parts List
SCX24 Dead Boldt https://www.amainhobbies.com/axial-...i-crawler-green-axi90081t2/p-qqzztzeq7b2xactz
Hot Racing Steering Rod https://www.amainhobbies.com/hot-ra...od-link-black-hrasxtf49x01/p-qqqeqqeqtzzzqctz
Emax Servo https://www.amainhobbies.com/emax-e...tal-gear-servo-emx-sv-0275/p-quaqtzwaycqxactz
Hot Racing 4mm wide track https://www.amainhobbies.com/hot-ra...stub-axle-set-hrasxtf39w04/p-qqqeqqeqtzzqqctz
Yeah Racing front steel drive shafts https://www.amainhobbies.com/yeah-r...t-driveshafts-yea-axsc-043/p-qqqeqsqahz2vqctz
Hot Racing Wheel Hex https://www.amainhobbies.com/hot-ra...wheel-hex-hub-4-hrasxtf10h/p-qqqeqqeqtzznqctz
Hot Racing brass axle weight https://www.amainhobbies.com/hot-ra...-hrasxtf39w04-hrasxtf2604h/p-qqqeqqeqtzzvqctz
Hot Racing brass diff cover https://www.amainhobbies.com/hot-racing-axial-scx24-brass-diff-cover-hrasxtf12ch/p-qqqrt2yqbc2eqctz
Hot Racing aluminum servo mount https://www.amainhobbies.com/hot-ra...k-hrasxtf2401/p-qqqvq2rqtmzwqctz#tab-feedback
SSD Scale Hubs https://www.amainhobbies.com/ssd-rc-1-24-scale-locking-hubs-blue-2-ssd00441/p-qqqetskq6cqyqctz
RC4WD Scrambler Tires https://www.amainhobbies.com/rc4wd-...-crawler-tires-2-rc4zt0146/p-qqaet2rq6c2xactz
RC4WD Stamped Steel Beadlocks (painted silver) https://www.amainhobbies.com/rc4wd-...k-wheels-white-4-rc4zw0111/p-qtalqseq6mzxactz
Electronics Parts List
WPL RES v3 Radio, Receiver, Sound https://www.wpl-rc.com/collections/radio-receiver/products/r-e-s-v3
Furitek Chameleon Brushed Motor https://www.asiatees.com/display?Mi...brand=Miscellaneous&model=All&id=201634&pid=1
Furitek Lizard 20A/40A Brushed/Brushless ESC w/ FOC https://www.asiatees.com/display?Mi...brand=Miscellaneous&model=All&id=188319&pid=1
Orlandoo Hunter Model Universal Lightbars https://www.asiatees.com/display?Or...odel&model=Orlandoo 1/35 F150&id=166039&pid=1
Micro Shark Parts List
SCX24 Micro Shark Frame https://www.shapeways.com/product/PGKTN4NCC/scx24-micro-shark-frame?optionId=121784684&li=ostatus
Chassis Parts for Micro Shark https://www.shapeways.com/product/P...ersion-deadbolt?optionId=121786397&li=ostatus
EMax ES08MAii Servo Mount (I ended up using the Hot Racing aluminum mount) https://www.shapeways.com/product/C...for-micro-shark?optionId=121785151&li=ostatus
Roof + Rear Panel https://www.shapeways.com/product/E...for-micro-shark?optionId=121964920&li=ostatus
Type T Hood and Grille https://www.shapeways.com/product/...or-micro-shark?optionId=122152917&li=ostatus
Type T Right Side Panel https://www.shapeways.com/product/...or-micro-shark?optionId=122152816&li=ostatus
Type T Left Side Panel https://www.shapeways.com/product/...or-micro-shark?optionId=122152549&li=ostatus
Fuel Cell and Cooler https://www.shapeways.com/product/4...for-micro-shark?optionId=121785673&li=ostatus
Seats https://www.shapeways.com/product/JJT22Y2A5/seats-for-micro-shark?optionId=122153497&li=ostatus
Dash https://www.shapeways.com/product/UUKLZKM6U/dash-for-micro-shark?optionId=122154204&li=ostatus
siiiick!
Sent from my SM-G973U1 using Tapatalk
hey you should paint that servo stem red to match the diff. or maybe black. [emoji848]
Very nice!
Is that the Orlandoo light bar? Curious how you hooked it up :)
Good eye! Yes, it is an Orlandoo light bar. You'll see in the video how I ran the wire. I'm using the WPL RES V3 as my receiver as seen in the G500 video (http://www.rccrawler.com/forum/micro-scale-rigs/627575-builders-notes-1-18th-mercedes-benz-g500.html), so I have a light unit built in along with winch controls and another on/off aux. I didn't put in a winch or other lights because this build is so CLEAN I didn't want to compromise it with more wires.
a few more pics...
a few more...
and the last batch...
That is really nice looking - one of the best Micro Sharks I've seen in terms of scale and fully fleshed out interior. Well done!
Put on some telescopic shocks. Or I guess some call them double barrels? :???:
Anyway, they originally caused the truck to sit too high, but I liked the extra travel they provided. So to compromise, I used soft springs from a shorter set of shocks. That way it still sits nice and low, but can extend when needed. The fact the springs are a little short doesn’t affect anything at this small scale. It’ll also rarely be at full flex. It increased my travel by 3/4 of an inch!
I finally found a driver that fits! I grabbed this 3.75 inch GI Joe off the store shelf.
I really didn't dig the military vibe, so I tossed on a coat of primer and found a helmet laying around. I think it looks good so far, but I wish it was about 3-5% smaller. I feel like it's a weeee bit too big.
I'm going to paint his jumpsuit a dirty white and add some logos. The helmet is painted Tamiya Dull Red. I'll probably keep that color, but I still need to blackout the goggle section. I might try to add some styrene trim around the goggles to give them some "depth", then maybe add a nylon strap for some realism.
More to come...
nothing wrong with being 7 1/2 feet tall.
tall people like to rock crawl too ya know [emoji23]
looks awesome man!! [emoji1360]
