brushless esc / motor ?
intheworks
winchester
not specific to crawlers
I picked up a LOSi ten scte that has a like new ESC and motor. the ESC is a MSC-MXPRO. it visually looks the exact same as the castle mamba max pro. The motor is a 550 4pole 2800KV sensorless.
My question for the wiser out there is, are these two speed controllers the same?
if not... can i run a sensored 4300 KV motor with the MSC-MXPRO?
would i be better off trying to sell the losi combo and just get the XR8 and 4300 combo?
Is this the ESC you have? Losi: 1/10 MSC-MCPRO Brushless ESC: Losi (LOSB9504)
If so, the specs are as follows (taken from that page):
Forward:Yes
Reverse:Yes
Brake:Yes
Time Delay Brake:Yes
Input Voltage:8.4V - 16.8V
Input Connector Types:EC3
Output Connector Types:4.0 Bullet Plugs
Motor Limit:No Limit (540 Size Motors)
Length:1.85 in (47.0mm)
Width:1.52 in (38.7mm)
Height:1.27 in (32.2mm)
Weight:2.83 oz (80.2g)
BEC Voltage:Programmable
PWM Frequency:12Khz
Overload Protection:Yes
Full On Resistance:.300 Ohms
Wire Gauge:13AWG
Auto Cutoff:Yes
But if you open up the manual, found here: http://www.losi.com/ProdInfo/Files/LOSB9504-Manual.pdf
It says:
Specifications
Motor Type Sensored and Sensorless
Brushless
Low-Voltage Cutoff Automatic Detection
Input Voltage LiPo 2–4S or 8.4V–16.8V
Full On Resistance .0018 Ohm
Motor Limit 4.5T 550 Sensored
Motor Output 13AWG
Lead AWG
Motor Connector 4.0mm Bullet Plug
Battery Input 13AWG
Lead AWG
Battery Connector EC3™
Type
Dimensions 45.5 x 36.5 x 21.5mm
(1.79 x 1.44 x .85 in)
Weight 81 g (2.8 oz)
(without wires)
BEC Output 5.5–7.0V
Turn to kv isn't a direct correlation and manufacturer specs vary so you are getting close to the limit with a 550, 4-pole 4300kv motor.
Forward:Yes
Reverse:Yes
Brake:Yes
PWM Frequency:12Khz
Wire Gauge:13AWG
Auto Cutoff:Yes
It says:
Specifications
Brushless
Motor Output 13AWG
Lead AWG
Battery Input 13AWG
Lead AWG
Type
(without wires)
BEC Output 5.5–7.0V
yes thats the ESC i have.
