Inspector86
Background:
I currently have five HH Crawl Master Pro 550 12T motors powering five of my rigs with the HW1080 ESC. Recently one of them stopped running while out trailing and after some investigation I discovered the commutator had worn to the point it lost one segment of contact. This concerned me as this motor had less than 30 hours of run time and had never been in sand, water or mud. I sent the motor in to HH for a rebuild and $80 later my motor was returned with a new armature and new brushes. It had obviously been run in when it came back with the start of a really ugly wear pattern on the com. So I disassembled the motor and noticed the contact surface of the new brushes is ribbed intentionally. This ribbing on the brushes strikes me as a really bad idea for long term wear.
modification:
Using a 4mm diameter round ceramic sharpening rod, I removed all traces of the ribs from the contact surface of the brushes leaving a nice polished surface in place of the ribs. Next, using a 1/2x1/4" 1000 grit flat honing stone I chucked the armature in my mini-lathe and polished the commutator to a smooth polished finish. After reassembling the motor and driving the truck for a little over an hour the wear pattern on the com is MUCH smoother with no trace of rib or groove wear and will likely last a long time without destroying the com. I have since done this polishing on my remaining four CM Pro motors as well. One of these four has significant wear on the com with around 20 hours of run time and will likely need to have the armature replaced on it as well but at least the polished brushes should slow the wear rate.
conclusion:
From a performance stand point can I understand about getting as much contact surface between the brushes and com as possible. But from a wear stand point this ribbed brush design feature is really sub optimal. From my perspective, I expect my motors to last a good long time without undue wear and I certianly don't expect a high end motor like this to die in 30 hours of runtime. After this, I plan to monitor my motors more closely and hopefully avoid having to replace another armature anytime soon. I actually tried calling HH to discuss this issue with them but no one answers the phone and a recorded message says to send an email. I would love to discuss this with JRH at some point and get his insight.
modification:
conclusion:
