tinyT1m7
I just recently bought a bomber and am now working on the suspension. Setup as of now:
Front suspension:
Proline powerstroke 88mm or close to 3.5"
Top mounted furthest hole from rear
Bottom mounted in furthest hole from rear as well.
Top spring is proline soft(green).
Bottom spring medium (yellow)
Rear suspension:
Proline power stroke as well 88mm
Top and bottom mounting holes closest to front of car.
Same springs as front shocks .
I just replaced the shock oil in all 4 shocks with 35wt and have the pistons rebound all the way out when pushed in; without the springs on.
I do a drop test with all electronics including battery in it from 3 feet and the bomber bounces back up 4 or more inches the higher I go. I am new suspension tuning, but I know this is not normal. What can I do to make the car absorb jumps and not bounce up after landing?
Front suspension:
Rear suspension:
