Bikeboy 4ws (4 wheel steering) Wraith build
bikeboy
vienna
Started on my 4 wheel steering
this is what I got so far for the axels
using stock gears,
VP axel
VP Truss
VP Shock link mount
VP Chubs
VP knuckles
VP Differential Covers
________________________________________________________
for the steering rods for front and rear
VP Wraith 3/16 Titanium Tie Rod
VP Wraith Titanium 3/16 Drag Link
Suspension Links
Chaotic Crawlers - Axial Wraith Suspension Links
Shocks
Junfac Gmade XD Piggyback Shock 93mm (2)
Spring I got the Losi 2.75" white, gold and Traxxas red - to be determine which one I will be using - later on
Shock oil is AE 30 - to start out with - will adjust later
Bearing is Fast Eddie Wraith Sealed Bearing full set - smooooth
Axial Wraith Bearing Kit
Looks very cool!
A quick question for you .... if you are using 93 mm shocks, do you have enough clearance for the rear servo, or does the battery tray or anything else hit it when the rear bottoms out?
I am considering doing a 4WS set up with stock shocks or the gmade 103 mm shocks, but I have a droop kit and it looks like I will have to raise the rear to do this....
Ironically I converted my 4ws to front only after I drove it for a month or so
Sent from my SM-N900V using Tapatalk
Great pics and detail, thanks! Did you have a computer radio so you could choose between 4ws and 2w, and never used it or you used a y harness and couldn't turn it off? Thanks!
