Best Brushed Motor for Brouncer
jeepnvinny
Everett, WA
Best Brushed Motor for Bouncer
What is the best brushed motor. I know this can be a little subjective, but to give you an idea of what I want to run it in, is this:
I currently have a Holmes Hobbies TorqueMaster Expert 540 motor, BRXL, and 3s in it and am wanting to see if there is something with more power.
This buggy is a performer when it comes to crawling. If I go brushless, won't I loose low end control? I also really like the BRXL... Would there be any brushless esc that would compare to the programmability?
not anymore!
Now that brushless motors come with sensor boards they can handle low end control just as good (if not better) than brushed motors.
What would be a good motor/esc combo for this application. I want to have good crawling ability too.
Thanks guys for the reply!
If you have the cash, I like the Castle Creations Mamba Max Pro and Tekin 3300. Great low end and incredible top end on 3s. I bought mine used and I'm very happy with it.
<TABLE cellSpacing=0 summary=Description cellPadding=0><TBODY><TR><TD class=descr> i have 5 pullers. i love the 10's the best. i wanna try out the New modle in 13T when i got the coin.
stright off Mr Holmes sight.
Discontinued motor. You can't find a more powerful brushed motor in this class. You get insane wheelspeed, more torque than any 540 motor, and the finest slow speed control. All in one motor. 7 slot armature allows for better throttle resolution with a high motor speed.
Recommended lipo battery-
6t- 2s only. 40a continuous
7t- 2 to 3s (3s may result in overheating). 45a continous 11.1v use, 35a continuous 7.4v use
10t- 2 to 3s. 40 amps continuous 11.1v use, 30 amps continuous for 7.4v.
14t- 3 to 6s. 35a continuous 22.2v use, 25a continuous 3s use
Slightly longer than a standard 540 motor. Uses standard 1/8" pinions, and 25mm motor mount spacing- bolts up like a normal 540 motor. **Some stock uses 4-40 mounting screws that are included**
Super Strong cobalt magnets
7 slot armature
6.9 ounces, 200g
2.5" long, 1.35" diameter
5-10 volts
160*F max
6t- TBD
7t - 2800 rpm/volt
10t- 1800 rpm/volt
14t- TBD
Badger's kick ass vid-
<EMBED height=355 type=application/x-shockwave-flash width=425 src=http://www.youtube.com/v/fJS4c36tcjs&hl=en wmode="transparent">
</TD></TR></TBODY></TABLE><TABLE class=product-properties cellSpacing=0 summary=Description><TBODY><TR><TD class=product-subtitle colSpan=3>Details
</TD></TR><TR><TD class=property-name>SKU</TD><TD id=product_code class=property-value colSpan=2>HH-CP</TD></TR><TR id=product_weight_box><TD class=property-name>Weight</TD><TD class=property-value colSpan=2>1.00 lbs </TD></TR><TR class=separator><TD colSpan=3></TD></TR><TR><TD class="property-name product-price" vAlign=top>Our price:</TD><TD class=property-value vAlign=top colSpan=2>$89.99 </TD></TR><TR><TD colSpan=3><TABLE cellSpacing=1 summary="Wholesale prices"><TBODY><TR class=head-row><TH>Quantity </TH><TH>Price</TH></TR></TBODY></TABLE>*Note:
</TD></TR><TR><TD class=product-subtitle colSpan=3>Options
</TD></TR><TR style="DISPLAY: none"><TD colSpan=3><SCRIPT type=text/javascript>//<![CDATA[var alert_msg = '';//]]></SCRIPT><SCRIPT type=text/javascript>//<![CDATA[/*variants array: 0 - array: 0 - taxed price 1 - quantity 2 - variantid if variant have thumbnail 3 - weight 4 - original price (without taxes) 5 - productcode 6 - W_is_png 1 - array: variant options as classid => optionid 2 - array: taxes as taxid => tax amount 3 - wholesale prices array: 0 - quantity 1 - next quantity 2 - taxed price 3 - taxes array: as taxid => tax amount 4 - original price (without taxes)*/var variants = [];/*modifiers array: as clasid => array: as optionid => array: 0 - price_modifier 1 - modifier_type 2 - taxes array: as taxid => tax amount*/var modifiers = [];/* names array: as classid => class name */var names = [];names[384] = {class_name: "Wind", options: []};names[384]['options'][1235] = "6t";names[384]['options'][1236] = "7t";names[384]['options'][1237] = "14t";modifiers[384] = {};modifiers[384][1235] = [0.00,'$',{}];modifiers[384][1236] = [0.00,'$',{}];modifiers[384][1237] = [0.00,'$',{}];/*taxes array: as taxid => array() 0 - calculated tax value for default product price 1 - tax name 2 - tax type ($ or %) 3 - tax value*/var taxes = [];/* exceptions array: as exctionid => array: as clasid => optionid */var exceptions = [];/*_product_wholesale array: as id => array: 0 - quantity 1 - next quantity 2 - taxed price 3 - taxes array: as taxid => tax amount 4 - original price (without taxes)*/var product_wholesale = [];var _product_wholesale = [];var product_image = new Image();product_image.src = "http://holmeshobbies.com/images/P/Cobalt-Puller-detail-01.jpg";var exception_msg = "Warning! This combination of variants of the product options cannot be selected";var exception_msg_html = "Warning! This combination of variants of the product options cannot be selected";var txt_out_of_stock = "Out of stock";var pconf_price = 0;var default_price = 89.99;var alter_currency_rate = 0;var lbl_no_items_available = "No items available";var txt_items_available = "item(s) available";var list_price = 89.99;var price = 89.99;var orig_price = 89.99;var mq = 100;var dynamic_save_money_enabled = true;var quantity_input_box_enabled = false;var max_image_width = 125;var max_image_height =158;var lbl_item = "Item";var lbl_items = "Items";var lbl_quantity = "Quantity ";var lbl_price = "Price";var txt_note = "Note";var lbl_including_tax = "including {{tax}}";//]]></SCRIPT></TD></TR><TR><TD class="property-name product-input">Wind </TD><TD class=property-value colSpan=2><SELECT id=po384 name=product_options[384]> <OPTION selected value=1235>6t</OPTION> <OPTION value=1236>7t</OPTION> <OPTION value=1237>14t</OPTION></SELECT> </TD></TR><TR class=quantity-row><TD class="property-name product-input">Quantity </TD><TD class=property-value colSpan=2><SCRIPT type=text/javascript>//<![CDATA[var min_avail = 1;var avail = 0;var product_avail = 0;//]]></SCRIPT>Out of stock </TD></TR></TBODY></TABLE>
im sure a puller would suit your needs, but really, with a rig like that... go sensored brushless. mmp and a pro4, you will be happy with the low and high.
As you can tell, everyone has their opinion of what works for their set up and driving style. I would say buy team brood, someone else would say "buy HH" and someone else would say "buy brushless" or tekin or ........
you get the point.
My suggestion would be to talk to the folks who make motors and ask them what they recommend for your set up. Its the best way to understand what is available and what will work - directly from the vendors. Educate yourself first, then ask opinions based on your educated choices.
eh, a few of us posting in this thread have been there and done that.
Until the Pro4's came out, I always recommended the 14t Puller on 6s (No Brood motor, or other vendor, can match it)... It is the best brushed motor out there IMHO. (I haven't seen/tried the new Pullers though.)
But now, my pullers are on the shelf (No, I will NOT sell them) and I run Pro4's.
I just switched out fofftarded II's pro 4 4600 for a 3300. Now it will crawl decently along with having a good amount of speed too. With the 4600 it wouldn't crawl ( duh :lol: ) but it had pretty much unusable top end since the chassis just couldn't take handle the speed. Once I re-gear it from 15/51 to 13/56 I'm sure it'll crawl soo much better and not give up too much up top either.
My suggestion would be right in line with everyone else, go brushless and NEVER look back. Also switching to lipo is never a bad idea if you haven't already.
not anymore!
Thank you! I continue to read that brushed is soooooo much better at the low end. It is good...absolutely...but THAT much better. I was starting to get concerned with what I was missing. I am so pleased with the slow control of the sensored brushless in my LCC and SCX10. I wouldn't change it, couldn't be happier and actually made a few converts.
X2 for that rig. The MMP is a great choice. Purely for options, Up to 6s and can handle pretty much any motor you throw at it.
I built a "bouncer" using gmade sides, twin hammers trans, ar60 axles blah blah blah. I went through 3 different motors. I finally bought a Tekin ROC 412 3100kv motor. Since i put the ROC in there I haven't looked for another motor. It's awesome. The MMP Pro4 3300 is awesome as well.
My bouncer is my avatar.
In this application I would also recommend sensored brushless, MMP and Pro4 3300.
BUT I would put a Team Brood Axle Buster up against a puller any day. "thumbsup"
I just put a HH 13T PRO hand wound arm in upgrading from a 27T sport machine wound arm and the performance is night and day. I am very pleased with the upgrade to a hand wound arm very smooth in the bottom and some good punch in the top.
Who made the chassis?
A pro4 would work great as other people have said. Another (cheaper) option is a 3656SD. It's slightly bigger than the pro4, pulls 1500w vs the 1000w pro4, has a much bigger rotor, and is less than $90. Either way a mamba max pro is the best speed control for the money to use with either motor.
