powder4breakfast
Being totally new to this hobby... I have both learned a lot and realized that there is a lot that just takes time and experience to learn. I don't know how a newbie would make it without online forums like this.
Therefore, I'd like to share my build in hopes that it helps another newbie like myself... and also so that I can ask some specific questions without starting more threads. This will be written as if it were the thread I was looking for when I started two months ago, not as a check out my awesome blingy rig... it's not.
The first thing to understand is that I am loving the rock crawling aspect. More than bashing, I really like technical crawling on rock - or trails with obstacles and climbing aspects along the way. Therefore my opinions are slanted towards crawling. As such, I am happy with the stock speed on 3s.
I have the Onyx 4000mAh 11.1V 3S. I get 1 hour 45 mins of mostly crawling (with a few changes I can now get 2-3 hours). I went with the Hitec X1 mini for my charger. I know nothing about chargers; but, I really like the X1 mini.
My OPINION on what basics are necessary for the RTR in order of importance if you view it as more than just a random toy to break out once in a while:
1) Servo, horn and BEC
These need to be changed right away... as in open box and swap out. I went with the Hitec 7954. There are countless posts about servos. Based on a lot of reviews I happened to go with this one. If it ever fails, I will move to the 7950 (I have since installed a 7950). I put on an Axial clamping servo horn and Castle BEC.
Keep the stock servo around for 2 speed conversion later if desired.
With this one fix alone, you should be able to have some fun and run the Bomber for a while. The next changes are performance based.
2) Spare tire
Move or remove spare tire. I tried to somewhat mimic Billinvic's mod for this and was able to move the spare forward about an inch. If you do not move or remove the tire, it will get hung up. There are some aftermarket solutions or you can get creative.
3) Sway bar.
If you like to bash or run a fast car, you may love the Axial soft sway bar. For climbing, it is too stiff and practically eliminates all flex in the back end. without it you get a lot of torque twist and the front end wont stay planted on climbs costing you traction.
I noticed that I could no longer side hill with the Axial sway bar installed without tipping over. I feel that the best option for crawling based on other reviews is the Vanquish Anti-rock or Dlux. I took a grinder and notched my Axial bar in 3 spots to soften it up to where I like it now (I eventually ended up with Vanquish Currie Anti-rock).
4) Turning radius
The Bomber needs tighter turn radius bad. I'm putting on the Vanquish Stage 1 kit (C-hubs, knuckles and rear lock-outs), VVD-hd and Vanquish clamping hexes all around.
With these changes, I feel that I would be fairly happy until items started breaking and I made changes based on necessity or desire.
My other list of mods include:
- Scale pieces: fire extinguisher, Hi-Lift, fuel cell Tube, shock lines and paint.
- Metal body panels while I learn to drive this thing. It has spent a lot of time rolling down things. I don't mind trashing cheap metal panels.
- Incision SS links and rods. Hopefully this and the knuckls and C-hubs add a little low weight to the front end.
From here we'll see where this goes. I think I've covered what I would feel are basic necessities to start with.
I will keep my stock suspension... at least until I have made other major changes that would affect weight etc. I have replaced oil levels. I have SSD wheels on the way and need to solidify what tires I'm going with.
EDIT to add current build/parts list:
vvv Build as of February 2017 vvv
- Axial RR10 Bomber RTR
- Duratrax Onyx 3S 11.1V 4000mAh 25C battery (2 - 3 hours crawling time)
- Hitec HS-7950TH servo
- Axial aluminum clamping servo horn
- Castle Creations bec
- Incision stainless steel tie rod and drag link with Axial (AX31186) 4mm off-set rod ends. These ends can eliminate the steering binding and castor issues that can be lost with some aftermarket diff covers or C-hub/knuckles
- Tekin Roc412 2300kv - sensored brushless
- Vanquish motor plate and motor cam - Black anodized
- Mamba Max Pro - ESC
- Robinson Racing 10T pinion
- D'Lux modified AR60 axle housings
- Beef Tubes - Brass (cut length of 1/8" round inside rear locker between axle shafts to eliminate side to side play and lockout rubbing)
- Axial H/D bevel gear 38T - Front
- Axial H/D bevel gear under drive 43T/13T - Rear
- Vanquish Stage One kit - Orange
- Vanquish knuckle bushings
- Vanquish AR60 knuckle weights
- Vanquish VVD V1-HD
- Incision spool/locker
- RC4WD Poison Spyder diff covers
- Pro-Line Pro-Spec rear 100mm shocks - Blue spring (super soft) 30wt oil - Front. Red spring (hard) 40wt oil - Rear
- Incision stainless steel links - Wraith length upper - Rear. Axial (AX31186) 4mm bent rod ends and 4mm shim to improve pinion angle
- Blue Monkey Wraith length trailing arms
- Vanquish Currie Antirock sway bar with Traxxas short turnbuckle links
- SSD Rock Racer Rims - including spare
- Pro-LIne Flat Iron XL - including spare
- Crawler Innovations Double Deuce 5.5 Medium - Front
- Crawler Innovations Double Deuce 6.0 Medium with outer ring removed - Rear
- Vanquish 12mm hex with Axial (AX3102 drive pins 2.0x11
- DMG spare tire mount Flat Iron XL + SSD Rock Racer rim + DMG mount = 0.60lb (currently removed - no spare)
- Star Wars themed painted panels and interior - Tamiya PS1, 2, 5 & 12 with Pez heads filled and drilled with epoxy putty
- Miscellaneous Hobby Gear and other scale pieces - Hi-Lift, Fire Extinguisher, Nos along with fuel tube and front shock lines
- 3mm shims next to rod end balls to eliminate slop with links
- Some new bearings - Fast Eddie I think? ...maybe Traxxas
Anything not listed is stock from RTR.
2) Spare tire
3) Sway bar.
4) Turning radius
