*****bec help******
trevely15
australia
Hey guy's, if you Esc turns your receiver on and with in a second turns it of.
Does that mean you need a bec to put more power into the receiver?. Because when i plug the Esc into the receiver it turns straight off.
And the Esc does have internal bec and thats whats i think has fried.
Thanks. Tom
is it used or brand new? maybe you freid something.. something like that happend to me when i was going threw some water.. i learned to stay away from water"thumbsup"
Did you pull ur power wire out of the esc? It's the middle one, red on most esc.. not sure if that effects it, just a thought...
First this should have been posted in the electronics section on the main page!
...second you need to state what brand and what model of electronics you are using!
...third, what turns off..the esc or the Rx?
...fourth, have you tried plugging in a different Rx or esc into the system to find out which one is bad?
On a different note....what is the outcome of all of the other threads you have started...I havent seen anything to say you are moving forward with any other issues...since the other threads are now inactive.
