backwards steering???
robert97dodge
Lufkin, Tx
Last night I started moving some electronics around on my AX-10. I moved the ESC to the front axle and the receiver is now at the front of the chassis. Also I took the blade connectors off of the motor and soldered the wires to the motor. That is all I did. Well when I plugged it all back in my steering is now backwards. I turn left it goes right. I am using the TQ3 remote and I havent had this problem before. When I helped a friend of mine build his a couple weeks ago his was doing the same thing but he has a high dollar remote and was able to reverse it with the remote. I dont see any way to do that with my remote. I thought that maybe the plug on the reciever was just backwards since it doesnt really show a certain way to plug it in but when I turn it around it doesnt do anything. It wont even go in forward or reverse.
The TQ3 can be reversed.
There are three switches on the base to the right of the off and on switch, labels CH.1, CH.2, Ch.3 switch the one your steering is pugged into.
Ok thanks a lot. That did it. I thought when you flipped those it just turned that channel off or something.
