Axial wraith wheels stop and engine revs?
Nemo
ogden
so i was doing some crawling with my wraith and noticed that sometimes my wheels wouldnt move and the motor would rev. it happened when the car was pushing against the rock with its front tires. i have a 45t tekin heavy duty motor so it should be able to handle it. i took apart the transmition and got everything back together, although everything seemed tight and in place. the motor works but something is wrong, what do i do?
+1 on the slipper. Wheels and drivetrain stay still and the motor still turns usually means your slipper is loose.
It worked!! i just took it all apart and reassembled everything making it all nice and tight. Thanks for the help.
When you say you made it all "nice and tight" how tight did you make it. The slipper clutch shouldn't be tightened all the way down, it's designed to have "slippage" so it doesn't destroy the gears......
Did you tighten it till the nut wouldn't turn, or just snug it down a bit.?
--Dan
