So, I have been tearing down and rebuilding trucks and trying my hand at body work, scratch builds, etc.
I want one truck that is mostly plug and play, nothing but fun.
Enter my new Unimog, UMG10 by Axial.
I will continue to upgrade and change things out, but this will stay mostly stock for a bit while I finish up other projects.
I used my after market Portal axles for this build, because, well, its a Mog. I also used my new bead lock wheels and tires because they fit the portals.
I need to buy a matching wheel and tire for spare.
I used a cheap roof rack as a body mount for accessories and added wheelwells upfront. The roof rack mounts between the roll cage bars. no modification was done or needed to cage.
I also modded (shortened) some Axial Scx10 II rock sliders to protect the body.
I also have a light kit laying around that I need to figure out. also will need a lightbar, etc.
I have been working on this last few days, which is why no updates on my other builds.
Specs:
ESC: Hobbywing Quicrun Crawler Brushed
Radio: FS-GT5
Servo: Annimos 20kg DS
Servo winch: Tiankongrc 25kg 360degree
Motor: RC4WD 45T crawler brushed
Battery: Zees 2s Lipo 5200mah
Axles: RZXYL Portal axles (cheap, wanted to try them)
Wheels: Mohero 1.9 aluminum beadlock
Tires: Injora Super Swampers 1.9
Shocks: stock aluminum shocks w/ 70w oil.
This was a kit build, mostly stock atm except for axles, wheels and tires.
Sent from my SM-J327T using Tapatalk
Specs:
Radio: FS-GT5
