axial steering issue
booher26
everett
I have the axial metal housing ends and the ckrc high steer knuckles. i have plenty of steering angle but it pushes extremly bad when at full turn. running the bender chassis with stock upper and lower links with axial rod ends. what adjustments can i make to the vehicle to make it turn instead of push thru hard turns?
The locked diffs pretty much kill the turning radius regardless of how much sterring angle you have. OPD gears up front (or UD gears in the back) wiill help a bit, but ultimately. installing a dig will give you the best turning radius.
Check the weight distribution, or C of G, of your rig. More weight toward the front will help solve your issue. A good place to start is to get it to balance at the front edge of the skid plate.
Cheers.
