Axial speed controll problem?!?
DannyDodge
Detroit
I got a wraith and changed the receiver out, now the speed control just constantly beeps, and I have no forward/reverse
I Tryed to set it up like the book says but it just gives me the 3 beeps, I hold full throttle and it just starts flashing the led on Esc and a constant beeping
sounds like your throttle trim needs adjusting..
adjust your steering trim and put the radio away from the rig..
start at neutral and move it up+ 1st..if that doesnt work try adjusting
trim down.
sometimes when im real close it wont arm itself,i can hold the radio away from the rig and it catches and arms itself.
holding full throttle will enter the programming mode on esc.
thats what the constant beeping is..
tuffguy was having this problem the other day when we went trail riding.
Double check your plugs on the receiver!...I had the same exact problem and i found that my BEC was plugged in backwards into the receiver...I got the same 3 beeps with flashing red/green lights, then constant beeping with no power to servo or motor!
I'll have to double check that thanks
trim down.
Illll Try that to, right now I have it set at 0
What radio are you using? Try doing reverse first.
First I Tryed the stock axial, thought maybe it was the controller, switche to a flysky. Still the same
