Axial Scx10 Pro and Reefs raw 500
A full size servo will hang below the tube. Pretty much even with the bottom of the diff. You can add spacers to raise it a couple mm, but go too far and the servo will hit the chassis brace under full compression. A low profile servo should sit pretty close to even with the bottom of the tube.
I ran a Holmes SHV650 (full size) for a year or so and it definitely showed some wear.
