Testing my waterproofed axles, servo and brushed 35T power system. Some clips are 2x speed. Using stock gears, no OD/UD:
<iframe width="640" height="360" src="https://www.youtube.com/embed/bBWjj66SLaI" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
Originally wanted to get 1.9 tires, closed cell foams and beadlock wheels so these could be disassembled and dried after running but some things were out of stock. Got cheaper wheel sets for mud and water instead. These were sold under brand name Absima as Steelhammer 108 mm and on photos they look identical to Banggood Hobby Master 108 mm crawler wheels. Plastic rims seemed a bit small for proper concentric alignment and the hex hub seems to have a lot less material than Axial stock wheels. So far no breakage even with one wheel stuck and slipper clutch slipping (spring tension as per manual). Covered the vent hole with tape and seems that no water got in. Did not want to risk with getting water into Axial wheels, happened once before and it took a long time to get it out.
