axial scx10 driveshaft problems
hntz4x4
elk grove
today i got the new scx10 honcho and i've already had to tighten down the front driveshaft 3 times. why is it doing this? do i need a longer screw? help me out please.
thanks
Your best bet for keeping the stock driveshafts attached is to use 3x5mm buttonhead bolts instead of the factory 3mm grub screws. I use part # HPIZ350. I like the HPI bolts because they tend to be either grade 10.9 or 12.9. They take a larger 1.5mm driver that you can really torque on. Since doing this I have yet to have a driveshaft fall off.
I even used red loc-tite, with two grub screws on each output, and I still couldn't keep them from falling off within a couple hours. It's kind of a design flaw, seeing as how the Wraith finally gets pins like Traxxas has been using for years.
Just take a 3/32 drill and make a hole through the stub shaft. Install the M3 Traxxxas driveshaft pins and you will have no more problems. They are exactly the right length so no trimming required. It is a little difficult to get the hole just right, so take your time. I tried the button head screw for a while, but even it fails. The problem is a button head screw doesn't have a bite ring like a grub screw. Eventually it will spin. Oh yeah, upgrade to the metal yolks.
Wes
thanks everyone for the advise. i just replaced the tiny screw with a bigger one and put lock tight on and it seemed to hold up better.
I have the Junfac shafts in my AX-10 and think that they are alright. The setscrews that hold the pin in loosen on a regular basis, even with red loc-tite. I had to double layer heatshrink over the ends to hold the pins in. I think that they bind a little when under torque because instead of splines they have a D shaped section for the slip, which effects suspension action. Like the rig will get bound up and lift a tire, and then when I let off the throttle the rig settles down.
They don't work at as steep an angle as the stock U-joints. I tried to run them in my SCX, but because of my additional downtravel and castor angle they bound up way before full droop travel. I attribute this to my added downtravel, my castor angle, and the slightly shorter wheelbase of the SCX compared to my AX-10.
While they have served me well, and I've only broken one pin in two years of heavy abuse, if I had to do it again I'd probably just get MIP's and be done with it.
Does anyone have a measurement of the maximum operating angle of an MIP shaft compared to the stockers? Or compared to Maxx shafts?
