Westside Charlie
The other day, I charged up my battery and set up the transmitter for my SCX 10 and my trusty crawler responded just as it should, and has, many times before. I powered everything down and headed out to a crawling spot. After powering up, I realized that the throttle was not responding. The truck lights were on and the servo worked fine. No power to the motor though.
Back at home, I went through the basic binding set up, and everything worked again. So I powered down, headed out again, but the same problem occurred. In the field I went through the re-binding process a few times, turning the power off and on, and at one point, the ESC responded, and all worked again. (Went on to enjoy a great crawling run.)
I'm thinking now that I probably have a bad connection somewhere and want to troubleshoot it. Before I start taking everything apart, I thought I would gather some recommendations about how to check everything out in a logical order. Here's what I know:
The battery is charged.
The motor works fine (when it works.)
Signals from the transmitter to the receiver seem to work, since the servo responds.
The LED lights on the truck light up fine.
Should I begin by checking the connections from the motor to the ESC, and then all the other connections?
