I picked up an Artful Dodger Designs Ground fox (1.1 I think) using the Element Enduro as the base combined it with a Trophy Rat body from Associated. I guess I'm building a Ground Rat
I'm impressed with the Ground Fox chassis, really nice fit and finish and the anodizing seems way tougher than I'm used to. Even the 3D prints are impressive, really good quality prints and the material seems slick (I think its ABS). I ended up ditching some of the prints so I could design my own, kinda felt bad because they are truly impressive prints.
Enduro Axles with Beeftubes up front SSD knuckles, C hubs, link mounts and diff covers, servo on axle mount included with the Ground Fox kit. The Enduro axle looks so much better with the SSD diff covers.
I went with GTS shocks because they worked amazing on the last build I did like this. Thinner oil and these shocks was a great combo on my sort of Twin of this build: http://www.rccrawler.com/forum/1-9-scale-rigs/619824-venduro-x4-2-dumpster-fire-build.html
Instead of running Enduro springs I picked up some of the softer Yellow Traxxas springs. I had some WB8 HD drive shafts on hand but had to grind down the ends a bit to get them to bolt up to the outputs on the Enduro tranny
Nice balance
I've used this body before, its nice but thin so I've made a cage to reinforce it. The rock sliders also protect the body. The body is from the Trophy Rat racer/basher which is why the lexan is pretty thin.
I built in a suck down winch using a RC4WD replacement winch motor/gearbox which is about $10. For those not familiar a suck down winch pulls the chassis down to the front axle. On a steep climb you can reel the suspension back in.
I 3D printed a spool and used a 3mm aluminum spacer as the center of the spool, tapped and threaded 2 holes to secured it to the winch motor shaft and to secure the winch line.
I'm using the HH Crawlmaster mini V1 ESC with a 2500kv Revolver running 3S. I added KNK 25% overdrive gears, had an issue meshing gears with the machined gears from factory team and had to pick up a set of the plastic gears. HH SHV800 servo and a Spektrum radio. There's and ESC under it but all you can see is the castle BEC which just runs the receiver and winch at 9v (6v wasn't really enough) the servo is running direct power.
Nice balance
