Are Foams Overhyped?
jwag1973
Saint Louis
I went out crawling today and ran into another crawler. His truck had some generic foam that was so soft it almost felt like his tires had no foam at all. He had Wore out Traxxas Canyon Trail Tires on hisTRX Sport. I could not believe the places he took his truck, and short of Overdrive front gears it was a beat up completely stock truck. I had Proline Krawlers (Predator) with Proline Dual Stage foams, and a set of R35 Maxxas Trepadors with C.I. Lil Nova Foams and couldn’t follow him waay to often. I didn’t expect much from the Trep’s as I use them a couple times a year when just trail running.
My gear was a New SCX10ii Cherokee with the Trep’s and a OG SCX10 fully upgraded with top of the line equipment running the Krawlers.
I accepted the guy was completely out driving me, but I was baffled that he was doing it with tires and foams I’d have thrown away!
What are this forums opinions on this type thing? I’m talking real crawling rigs, not shelf Queens! In real world crawling is this the norm....or did I just run across a BMF that’s the exception to the rule?
The Canyon Trails are actually not a bad tire once they get a little broken in and imo with a little softer foam than stock. Did you see if he had cut/ siped them? That could've added a bit more capability. And foams aren't over-rated imo... there's a lot of different density foams out there and depending on conditions and terrain, sometimes a cheapo/ stock/ firmer/ single stage foam will do better than an ultra-tuned 3-stage aftermarket foam. It really just depends on all factors combined. Plus the fact that if this guy knew the area, had run the same trails/ lines already and you hadn't, then that could give him some advantage too... not to mention how well someone knows their rig. Often times, you can't really see very subtle driving differences between you and someone else, but those little unapparent nuances can really add to successful execution. JMO.
Canyon trails are typically regarded as rather good tires. "Wore out" tires can actually work really well in some conditions, sometimes better than brand new. TRX4 Sport is a great performing truck out of the box, arguably the best at its price point. Really soft foams can work really well for climbing, but can lack the stability for side-hilling, and other scenarios where the tire wants to fold over on itself.
Agreed. Canyon trails aren’t a bad tire. But the truck matters a lot too. For example, here’s a clip of my trx4 with cut Canyon trails and upgrades basically everywhere else
Are your Krawlers vented?
<blockquote class="instagram-media" data-instgrm-permalink="https://www.instagram.com/p/B7PGqfIAU6G/?utm_source=ig_embed&utm_campaign=loading" data-instgrm-version="12" style=" background:#FFF; border:0; border-radius:3px; box-shadow:0 0 1px 0 rgba(0,0,0,0.5),0 1px 10px 0 rgba(0,0,0,0.15); margin: 1px; max-width:540px; min-width:326px; padding:0; width:99.375%; width:-webkit-calc(100% - 2px); width:calc(100% - 2px);"><div style="padding:16px;"> <a href="https://www.instagram.com/p/B7PGqfIAU6G/?utm_source=ig_embed&utm_campaign=loading" style=" background:#FFFFFF; line-height:0; padding:0 0; text-align:center; text-decoration:none; width:100%;" target="_blank"> <div style=" display: flex; flex-direction: row; align-items: center;"> <div style="background-color: #F4F4F4; border-radius: 50%; flex-grow: 0; height: 40px; margin-right: 14px; width: 40px;"></div> <div style="display: flex; flex-direction: column; flex-grow: 1; justify-content: center;"> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; margin-bottom: 6px; width: 100px;"></div> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; width: 60px;"></div></div></div><div style="padding: 19% 0;"></div> <div style="display:block; height:50px; margin:0 auto 12px; width:50px;"><svg width="50px" height="50px" viewBox="0 0 60 60" version="1.1" xmlns="https://www.w3.org/2000/svg" xmlns:xlink="https://www.w3.org/1999/xlink"><g stroke="none" stroke-width="1" fill="none" fill-rule="evenodd"><g transform="translate(-511.000000, -20.000000)" fill="#000000"><g><path d="M556.869,30.41 C554.814,30.41 553.148,32.076 553.148,34.131 C553.148,36.186 554.814,37.852 556.869,37.852 C558.924,37.852 560.59,36.186 560.59,34.131 C560.59,32.076 558.924,30.41 556.869,30.41 M541,60.657 C535.114,60.657 530.342,55.887 530.342,50 C530.342,44.114 535.114,39.342 541,39.342 C546.887,39.342 551.658,44.114 551.658,50 C551.658,55.887 546.887,60.657 541,60.657 M541,33.886 C532.1,33.886 524.886,41.1 524.886,50 C524.886,58.899 532.1,66.113 541,66.113 C549.9,66.113 557.115,58.899 557.115,50 C557.115,41.1 549.9,33.886 541,33.886 M565.378,62.101 C565.244,65.022 564.756,66.606 564.346,67.663 C563.803,69.06 563.154,70.057 562.106,71.106 C561.058,72.155 560.06,72.803 558.662,73.347 C557.607,73.757 556.021,74.244 553.102,74.378 C549.944,74.521 548.997,74.552 541,74.552 C533.003,74.552 532.056,74.521 528.898,74.378 C525.979,74.244 524.393,73.757 523.338,73.347 C521.94,72.803 520.942,72.155 519.894,71.106 C518.846,70.057 518.197,69.06 517.654,67.663 C517.244,66.606 516.755,65.022 516.623,62.101 C516.479,58.943 516.448,57.996 516.448,50 C516.448,42.003 516.479,41.056 516.623,37.899 C516.755,34.978 517.244,33.391 517.654,32.338 C518.197,30.938 518.846,29.942 519.894,28.894 C520.942,27.846 521.94,27.196 523.338,26.654 C524.393,26.244 525.979,25.756 528.898,25.623 C532.057,25.479 533.004,25.448 541,25.448 C548.997,25.448 549.943,25.479 553.102,25.623 C556.021,25.756 557.607,26.244 558.662,26.654 C560.06,27.196 561.058,27.846 562.106,28.894 C563.154,29.942 563.803,30.938 564.346,32.338 C564.756,33.391 565.244,34.978 565.378,37.899 C565.522,41.056 565.552,42.003 565.552,50 C565.552,57.996 565.522,58.943 565.378,62.101 M570.82,37.631 C570.674,34.438 570.167,32.258 569.425,30.349 C568.659,28.377 567.633,26.702 565.965,25.035 C564.297,23.368 562.623,22.342 560.652,21.575 C558.743,20.834 556.562,20.326 553.369,20.18 C550.169,20.033 549.148,20 541,20 C532.853,20 531.831,20.033 528.631,20.18 C525.438,20.326 523.257,20.834 521.349,21.575 C519.376,22.342 517.703,23.368 516.035,25.035 C514.368,26.702 513.342,28.377 512.574,30.349 C511.834,32.258 511.326,34.438 511.181,37.631 C511.035,40.831 511,41.851 511,50 C511,58.147 511.035,59.17 511.181,62.369 C511.326,65.562 511.834,67.743 512.574,69.651 C513.342,71.625 514.368,73.296 516.035,74.965 C517.703,76.634 519.376,77.658 521.349,78.425 C523.257,79.167 525.438,79.673 528.631,79.82 C531.831,79.965 532.853,80.001 541,80.001 C549.148,80.001 550.169,79.965 553.369,79.82 C556.562,79.673 558.743,79.167 560.652,78.425 C562.623,77.658 564.297,76.634 565.965,74.965 C567.633,73.296 568.659,71.625 569.425,69.651 C570.167,67.743 570.674,65.562 570.82,62.369 C570.966,59.17 571,58.147 571,50 C571,41.851 570.966,40.831 570.82,37.631"></path></g></g></g></svg></div><div style="padding-top: 8px;"> <div style=" color:#3897f0; font-family:Arial,sans-serif; font-size:14px; font-style:normal; font-weight:550; line-height:18px;"> View this post on Instagram</div></div><div style="padding: 12.5% 0;"></div> <div style="display: flex; flex-direction: row; margin-bottom: 14px; align-items: center;"><div> <div style="background-color: #F4F4F4; border-radius: 50%; height: 12.5px; width: 12.5px; transform: translateX(0px) translateY(7px);"></div> <div style="background-color: #F4F4F4; height: 12.5px; transform: rotate(-45deg) translateX(3px) translateY(1px); width: 12.5px; flex-grow: 0; margin-right: 14px; margin-left: 2px;"></div> <div style="background-color: #F4F4F4; border-radius: 50%; height: 12.5px; width: 12.5px; transform: translateX(9px) translateY(-18px);"></div></div><div style="margin-left: 8px;"> <div style=" background-color: #F4F4F4; border-radius: 50%; flex-grow: 0; height: 20px; width: 20px;"></div> <div style=" width: 0; height: 0; border-top: 2px solid transparent; border-left: 6px solid #f4f4f4; border-bottom: 2px solid transparent; transform: translateX(16px) translateY(-4px) rotate(30deg)"></div></div><div style="margin-left: auto;"> <div style=" width: 0px; border-top: 8px solid #F4F4F4; border-right: 8px solid transparent; transform: translateY(16px);"></div> <div style=" background-color: #F4F4F4; flex-grow: 0; height: 12px; width: 16px; transform: translateY(-4px);"></div> <div style=" width: 0; height: 0; border-top: 8px solid #F4F4F4; border-left: 8px solid transparent; transform: translateY(-4px) translateX(8px);"></div></div></div> <div style="display: flex; flex-direction: column; flex-grow: 1; justify-content: center; margin-bottom: 24px;"> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; margin-bottom: 6px; width: 224px;"></div> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; width: 144px;"></div></div></a><p style=" color:#c9c8cd; font-family:Arial,sans-serif; font-size:14px; line-height:17px; margin-bottom:0; margin-top:8px; overflow:hidden; padding:8px 0 7px; text-align:center; text-overflow:ellipsis; white-space:nowrap;"><a href="https://www.instagram.com/p/B7PGqfIAU6G/?utm_source=ig_embed&utm_campaign=loading" style=" color:#c9c8cd; font-family:Arial,sans-serif; font-size:14px; font-style:normal; font-weight:normal; line-height:17px; text-decoration:none;" target="_blank">A post shared by topher Builds (@topherbuilds)</a> on <time style=" font-family:Arial,sans-serif; font-size:14px; line-height:17px;" datetime="2020-01-12T22:21:58+00:00">Jan 12, 2020 at 2:21pm PST</time></p></div></blockquote> <script async src="//www.instagram.com/embed.js"></script>
The guy had been going there regularly so I suppose that may have been a factor as I’ve been there three times total. The other two times I took my 11 and 13 year old daughters basically following the trails and crawling obvious rock and terrain along the path.
He showed me some areas I’d seen but hadn’t crawled before today, and truthfully wasn’t sure if they were crawlable. After seeing him head up into a steep mixture of moist sandy dirt and rock with relative ease, I figured I could do the same or very similar. Honestly looking back, I’m sure the fact he was very familiar with the terrain and lines played a bigger part than I initially thought. Though in all honesty...he told me and showed me where to go and I still struggled to keep up! I’m going back tomorrow morning and gonna try some of those lines again.
Normally I try to crawl with a little finesse and the lines he took I’m not sure if you can. It appeared that you needed to be fairly aggressive to make those lines work!
The Krawlers weren’t vented, a major oversight on my part! I just bought them and a set of Mud Terrain in Predator and did not vent the Krawlers, I thought I did but only vented the Mud Terrains.
I think the difference between a first gen scx10 and a trx4 was also on display.
I think I’d have to agree! I recently bought both my daughters SCX10 ii’s as I already was invested in Axial. If I had it to do again I think I’d have gone with Traxxas!
Agreed, nice outline drifter.
Stiffness of chosen tires, Conditions, driving ability, familiarity with lines and terrain all dictate what foams might be appropriate in a moment. Experience through experimenting has taught me that all the different style of foams can potentially work. If tires and foams weren’t so bloody expensive I would stuff my favourite 4-5 tire sets each with 2-3 different foam styles. "thumbsup":ror:
I dont own a Traxxas at all but the original scx10 has big diffs that hang low especially in comparison to a next generation of crawler
I just got home after heading back out to the state park I crawled yesterday. I spent most the day out there running the same two rigs with the exception that I vented the Krawlers and Swapped my Hyrax back on my Cherokee. What a difference a day makes!
I had the place to myself in regards to crawling and was able to get some productive work done. I’m not going to say I have the spot mastered, but I learned a lot...and I’m very happy with the progress I made. I was able to figure out how to navigate most the lines the way I like to drive, and I’m still working on a few lines I couldn’t make work the way I wanted them to. Yesterday was pretty much what I’d consider bashing or rock bouncing, not my preferred method of crawling. My rig took a beating yesterday and his was already beat to death. Today was a completely different story.
I was pretty aggravated and frustrated when I got home yesterday, not rationally thinking about it!
I think our differing driving styles played a part as well. He forced his truck to go where he took it or it went for a tumble.(Which was quite often). I tried the same thing and believe that made my day worse as I was tearing my trucks up, and having little success.
The properly vented Krawlers and Hyrax both worked great today, and I’m looking forward to getting back out there again, hoping to build on the knowledge and experience I gained today. The foam thing was probably more pure frustration than anything else.
I do think aftermarket foams are way over hyped. They provide much better lateral support that is most noticeable when side hilling. As long as your foams aren't much too stiff or much too soft I don't think it's a huge deal. The wrong aftermarket foams can hurt performance more than they help.
What size foams are you running? I think Eddie (CI) over-sizes his foams a bit. For a 4.75" tire I prefer running his 4.5" foams for a good combination of grip / sidehill performance. For most rigs (even heavy ones) I feel like the 4.75" inners are too tall. That said I still 100% believe that CI foams are a way better starting point than just about anything out there.
But yeah, as others have mentioned, setup, driving style, ect. all play a role in how we'll you'll do on the rocks.
