Has anyone ever had any binding issues in the front of their capra? I can only flex my front suspension about half way before it lifts the truck. I took out the pen springs i had in it to eliminate the possibility that the internal spring was causing issues but that wasn't it. Even with the pen spring and the bottom shock cap off it still didn't put any droop in the spring. I suspect binding somewhere but i have no idea.
Rtr stock shocks with red springs 45k oil, 540 axe system 2100kv, no dig servo. I can force the suspension to compress but it takes enough force that it forces the belly and cage to flex a little. I will take the whole thing apart tonight but curious if anyone has any ideas.
This is as far as the shock travels under its own weight and without bottom shock caps.
This is the bottom if this helps anyone see anything i don't.
