Anybody using these ?
They should fit as they have the pin slot, but keep in mind they also space the wheel out.
If you look at the parts picture, they provide a female extension to screw onto existing axles.
In my experience setups like these will loosen every few minutes and wheels will fall off. This is a terrible setup due to the barrel screws that are used and the huuuuge extension which will make for a really bad scrub radius.
I wouldn't even consider this as an option.
Ditto to what he said.
And, running any kind of long extension like that virtually guarantees that your axle shafts will get bent.
