Anti foam size? (3D printed foams)
pchiumiento
Mass
Do people normally order a different size 3-D, printed anti foams depending on the tire size? Like class one, 1.9 tires or class 3 1.9 tires? Do you order different sizes for those because of the tire size difference?
P2K R/C
Where I got mine from, I was asked not only tire size but brand and model.
I don’t think 3D “foams” made for 4.19 would work all that well in a 4.75.
The printed inserts are more picky than typical foams as far as size of tire. Need to get a insert that matches your tire & wheel setup to work properly. I have 2 custom sets made by Nebula RC for 2 different wheel & tire setups along with truck weights.
That’s exactly what I have been looking for where I have been getting mine only makes 1 size and takes forever to get them to me. Thank you.
P2K R/C
I have recently found Nebula and they ask all kinds of questions when making a no foam as these call it for your vehicle also they have different types depending on what you want them for. Sounds good I’m going to give these ones a try see how they work. I will update with a post when I finally get to use them.
P2K R/C
