  • RCSC
Amphibious Lurker (Sherp ATV)
Shape_Shifter
Parker, CO
A hell of a lot of fun!
This is the King Kong RC Lurker kit. It's a scale replica of the full size Sherp ATV. It has a wild three-motor drive train that run through three differential gear boxes. Its a tractor steer, but doesn't require any programming or special controller. Any two channel RC unit will work.
I built the kit in pretty much stock form but I painted a few things and designed and installed the LED lights.
<iframe width="560" height="315" src="https://www.youtube.com/embed/CSuQtBhDgbc?si=NmDd7bSbve4_qZ-1" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen=""></iframe>
After breaking through the ice and trying to get out, it took on a lot of water over the transom so I decided to make a bilge-pump.
<iframe width="560" height="315" src="https://www.youtube.com/embed/lEDpEVDOm0g?si=cYpBE9iVyNFC7Pim" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen=""></iframe>
I got this tiny 6 volt pump on ebay. Not sure what it's originally for.
I designed a mount bracket for it in AutoCAD.
I printed the prototype in green, but the final part I printed black.
The bracket clamps over the side drive belt rail and holds the pump flat against the bottom of the hull (chassis?).
I use some silicone tubing I had laying around to mount to the riser pipe.
I also designed and printed the riser pipe.
The pump is a little taller than the lower battery deck so I had to cut a relief hole. This lower deck is covered by the upper deck and can't be seen when running anyway.
I wired the pump to the Aux channel using an RC switch module so I can turn the pump on and off from the transmitter.
Sweet, love the Sherpa, a boat with wheels. Great running in the video , looked quite controllable in that water
Yeah the video was mild because I was trying to drive and video at the same time, but I spent a lot of time out on the water. Im surprised how well the tires propel this thing.
Have you seen that bilge pump working on you rig? Do you have a link for the pump? I'm looking for something like that for a project I have.
I used one like this to cool a small 2gal pot still worm, for hobby purposes only, during covid layoff. Supplied power to it with a 2s lipo. It moved a decent amount of water from an ice chest of iced water.
https://www.ebay.com/itm/2645113114...-mvR2LQQfe&var=&widget_ver=artemis&media=COPY
Yep, that's the pump!
