Obviously you have no idea what you talking about:mrgreen:...did you ever try A.L.T inserts ??that foam has a tendency to get flat spots that wont go away the holes will only make it worse
no but i made some like that out of closed cell foams and in my aplication they suckedObviously you harve no idea what you talking about:mrgreen:...did you ever try A.L.T inserts ??
I realize that alsoCI foams run large in 1.9s. 4.5 with the tuning rings removed are perfect for any 4.75" tire. They always start too large until they break in anyway.
Well...in a way the ALTs are two stage ...the foam in the center is firmer than the outside;-)Do you understand that you are not comparing similar products? The Lil Nova is a Dual Stage foam. The competitor foam is a single stage. If you are after a similar comparison, the Deuce's Wild is a single stage foam like your competitor.
i just ran accross the new alt drag wheels and tires made specialy for there foams 1.9 and 2.2 available
