affordable sensored 3s brushless system for LNC?…some advice needed please 🙂
mudholestomper
Houston
Hey guys and gals…I've got a mostly stock LNC that I'm considering going brushless with - per the thread title, I'd like to go with 3s and am interested in a bit more wheel speed - I'm not looking for a burner, as I've already got a heavily modded brushless emaxx with tekin power and 2 heavily modded stampede 4x4 vxl's to quench my thirst for speed and broken parts 😜
As it sits, the LNC has had a recent full tear down/rebuild including a shock rebuild/new bearings throughout/worms re-packed and shimmed properly - I've also thoroughly read through/applied the friction reduction knowledge from the thread on this very forum
as far as upgrades go, a full set of hot bodies rover ex tires (and foams) in the white compound have been ordered and will be installed on the factory Losi wheels - I've installed lead wheel weights inside of the wheels, front and back, with a total of 3oz in each wheel (on a side note, I think I've read somewhere that only the fronts should be weighted/the fronts should have twice as much weight as the rears???…any guidance on this would be greatly appreciated 👍)
besides the new tires, I intend to purchase/install the 21t HD worms front and back (see my intended use below) - right now I've got a Yeah Racing Hackmoto brushed setup with a 55 turn, 540 sized motor running the stock 20t pinion and a turnigy 2200mah 3s 25c/50c lipo providing the getupandgo - the servo is TowerPro mg996r running off a cc bec set at 7.4v with the factory rx running off of the esc's bec - I know the servo is nothing to write home about, but setup as it is, it is quite sufficient for my intended useage
I have zero interest/intentions in competition for this project - what I intend to do with it is to pack a light lunch and a backpack with some basic hiking supplies/water/etc, strap on some proper hiking shoes, charge up a couple of high capacity 3s lipos and some spare transmitter batteries, find the nearest woods, and go for a proper explore/hike with my crawler - I enjoy hiking/exploring and need the exercise…let's just call this crawler my hiking buddy/exercise partner 👍😎
with the current electronics setup, the LNC is slightly slower than my average walking pace - I'd like it to move at a jogging pace for short bursts - I know it's not intended to be run at speed for any length of time and I don't want it to do doughnuts or jumps
I WOULD, however, like it to provide a bit more excitement when it's powering up and down ditches…I'd like it to traverse the patches of flat earth between obstacles faster…and i'd like it to have a broader, more diverse (if that makes sense), useable power band when I encounter obstacles that…ahem…aren't behaving and need a bit more aggression to whip them into shape - with the current brushed setup, the power band, while smooth when needed, is sort of "off or on", with very little useable speed/power in between full throttle a no throttle…particularly when I am simply going on a walk through the woods with it (and given that it's very realistic to experience fairly large areas of flat earth between crawlable terrain)
I don't need the brushless system to be waterproof (and am well-versed in diy waterproofing if needed/desired) - I would like it to fit the crawler without extensive modification of the factory esc/motor mounting locations - and since I'm a single dad with two elementary school aged kiddos, I'm on a pretty strict budget
now, with all of that being said, I'd like to spend around $100-$125…$150 would really be pushing it…but my point is that I don't have $150-$175 for a tekin/Novak motor, let alone the type of money it would take for one of their high-end combos
Any advice/guidance will be greatly appreciated!
Re: affordable sensored 3s brushless system for LNC?…some advice needed please 🙂
I looked at the hobbywing quicrun setup that mindless mentioned and it appears to be what I'm looking for - they offer a 3650 sensored motor that comes in 13.5t, 17.5t, and 21.5t (2500kv, 1900kv, and 1700kv, respectively) - they mention in their notes that the 21.5t is the "crawler" option, but I have to admit that the 13.5t, with its MUCH higher RPM potential/range, particularly on 3s, sounds MUCH more interesting - I've read of folks using a 13.5t motor in the LNC, geared properly of course
So what are the opinions on this esc/13.5t setup for the LNC?
And, as always, thanks!
I run one of these in my wraith for the price im pretty happy with it HOBBYWING North America — QUICRUN 10 Sensored ESC. I have a LCC that ive been building was going to try it in there but havent had a chance yet.
I can't claim to know a lot about the wraith, but what motor are you using with this esc?
I was running a tekin 13.5 and it was fasstttt but could crawl still. In a losi would be a good bit slower. I say 13.5 or 17.5 would be good, I think I would go 17.5 but thats just me. Others are more knowledgeable than me with this sort of thing.
using a tekin 17.5t gen 1 myself. there are times that i really wish i had more wheel speed. i know a ton of people are running 13.5t's and love them. you could go the gijoe route instead and run higher voltage as an alternate with something like a mamba max pro.
My advice would be to find a used MMP or Holmes ble. It may take a little time but you can get great stuff at half the cost. There always is some risk in buying used but if your on a budget (and who isn't) its a good option. BTW 4s is the way to go with a losi.
I don't have a problem searching for a mmp (and already have a castle link), but 1. I don't own any 4s packs (but have lots of 5000mah 2s packs, although mounting 2 of those huge packs in the stock LNC battery tray would amount to a VERY high cog) 2. I'm interested in having a reliable rig that is not going to snap axles/strip the trans/strip a wheel hex/heat up or wear out worms and or housings/bearings/blah/blah/blah…again, I'm not trying to build the ultimate, tear-your-face-off, reverse the rotation of the earth night crawler 3. my primary r/c interests lie in high speed bashing - I've got a tekin rx-8 gen2 and tekin racing truggy motor (drawing a blank on the model right now) in my emaxx and I don't even have the need for 6s in that truck - I run it on 4s - the LNC is a side project to go along with another hobby (hiking) and I just don't have a need for a huge, 6s capable esc nor do I want to strap on the kind of motor that would be preferable when running 4s - I may be wrong, but I am of the opinion that if I put my tekin setup from the emaxx into this crawler, with its 48p gears and 1/10 scale driveshafts/wheels/hexes/diffs/etc, it would tear something in half the second I grabbed some real throttle
In other words, an 1/8 scale esc/motor on 1/8 scale voltage is overkill for what I'm asking of this vehicle
but please don't get me wrong, I 100% appreciate y'all taking the time to reply and appreciate the suggestions! - please keep em coming!!!
Go onto tower, they got some super cheap brushless motors. Or search ebay, I'm sure you will find something you like.
I know all of (more accurately: most of) the avenues for finding r/c parts…I've been playing with these overpriced toys for 20 years 😳
I'm simply looking for experienced suggestions that are specific to this model and are in line with (what I thought was) a very clear, concise, and thorough explanation of my intended use
I appreciate it, but telling me to look at tower hobbies/eBay is about as helpful as telling me to be sure to turn on my tx before my esc 😜
now, what could motivate folks into helping me out more than rudeness and smartassery?.................. I certainly can't think of anything
hobbyking xcar - 17.5turn works perfect for me.
you want something that is about 2000kv and can do both 2cell and 3cell
check my LNC math threads
Re: affordable sensored 3s brushless system for LNC?…some advice needed please ��
I'll check it out (and the math threads) - most 540 sensored (and reasonably priced) combos I'm finding offer the motor in 13.5t, 17.5t, and 21.5t (roughly 2500kv, 1900kv, and 1700kv)
The simple math:
2500 * 11.1 = 27,750rpm
1900 * 11.1 = 21,090rpm
1700 * 11.1 = 18,870rpm
in trying to determine which kv would be best, it would be supremely helpful if I had some idea as to what my rebuildable 55turn yeah racing Hackmoto brushed motor (with bearings as opposed to bushings…it's a damn smooth, free-spinning motor) was doing rpm-wise on 3s…but I can't, for the life of me, find even some general information as to how fast it may be spinning - my best educated guess is around 12,500rpm at WFO throttle
