Ae-2 esc or reciever problem
17mrman
USA
hi, i have a AE-2 esc and a wraith reciever and i was rock crawling and it shut off. and i cant get it to turn back on, no lights, no sound, no nuthin. please help!:roll:
Is the RX light on?
Try fully charging your battery and check ALL the connections. The motor leads, battery leads, servo leads into the RX...everything. look over the servo/esc plugs to ensure the tiny pins are still held into the plastic plug.
Are you running the stock Tamiya/Molex connector? Look them over for security, the AE-2 ESC will not beep unless plugged into a motor.
Is the ESC switch actually working?
Is the RX light on?
If you are running Tamiya connectors, change them soon, they WILL fail over time.
The ESC does not "beep", it "buzzes the motor" to make the arming sound.
