Adjusting Brushless motor timing
DrDiff952
Knox, IN
What do you do when your motor isn't marked clearly, I know I want this thing as close to zero advance as I can get it but which way to turn it? :?:
Hera is a pic of my motor 17.5 turns 2 pole sensored:
That's a confusing marking if any...
At least on this motor it's marked more clearly. (I have one of same type. Notice that the minimum timing here is 15 degrees.)
For a crawler I'd discourage tha choice. I use the 17.5T version and am not satisfied with the (lack of) smoothness at very low speed.
That motor is better used in my drift car, not using the sensor.
