bassbusta01
2.2 sportsman
Chassis - 5th Dimension Suckerpunch
Axles - AR60 with under/over ring and pinions, Dlux servo/link mounts
Wheels - CI 1"
Tires - Proline Chisel
Foams - CI - front - narrow inner/med outer, rear - narrow inner/soft outer
Links - Lowers - stainless and/or aluminum tubing over stainless 8-32 all thread with Jato ends, Uppers - Aluminum tubing over stainless 440 all thread with traxxas 1942 ends.
Shocks - Dravtech with 40wt front 30wt rear. I'm not sure which of the springs I will use yet. I have a set of all the available rate springs from Dravtech.
Trans - AX10 with RR hardened output.
Motor - 55T
ESC - Axial AE-5
Servo - Hitec HS-7955tg (noisey little thing)
Radios - Futaba Fasst
Batteries - Venom Graphene 3s 650mah
Body - Parma exciter, losi mini crawler for temporary until parma gets paint lol
LMK what you think. I'm pretty new to all this.
Where can I find out about local clubs/events? I'm in CA, near the coast between Santa Cruz and SF.
Charging batteries now. I cant wait to test this thing out on some real rocks.
Good test run today on some sandstone rocks down the street. No video yet, as I was alone. I plan on heading out to the beach sometime this week for more testing. Maybe I'll get some video.
Thanks to everyone on Rccrawler for all the build threads and info. Thanks Cboggs for the help with battery choices.
This build started years ago as a TLT crawler but I never finished it. A few months ago I pulled out the box of parts and started to pick up where I left off. I quickly found that things had changed quite a bit since then so this is what I ended up with. Lol.
Found info on local competition. Looks like april 15th is a comp at Rockaway Beach. I just might have to go visit.
Wheels - CI 1"
Motor - 55T
ESC - Axial AE-5
