SMT_Digger
Hello everybody,
New guy here. Don't have a crawler yet but one is in the future. What I do have though is the Axial SMT10 Grave Digger that I've purchased for my son and have been slowly modding it to be pretty awesome, but have hit a hiccup with the 4 wheel steering. I know this isn't a monster truck forum, but since 4WS can be a common thing in the crawling world I figured I would come here to see if I can get some help.
So I've upgraded the electronics in the truck, to include a hobbywing max10 4000kv brushless combo, Spektrum DX5C transmitter with spektrum 6100 5 channel receiver. It has AVC but I'm not using it for my application. Ive molded the rear AR60 axle with the knuckles and axle pieces to accommodate rear steering, along with beef tubes on all axles, upgraded links/trailing arms, jconcepts tribute wheels with goldenyears tires, and GPM tie rods/steering linkage. The rear servo has the axial 23t aluminum servo horn, and the front has the stock servo saver, which is very stiff i might add. A servo horn to match the rear is on the way. Both servos are Spektrum 614s.
The problem I'm having, is getting the steering aligned. After binding the transmitter and setting steering and throttle end points, the front axle wants to turn to the left. To get this straight, I have to adjust the trim so somewhere around 70-80 to get it to track straight. To add to this, when setting up the 4ws with the rear in aux3 set to button D, it also wants to turn and requires around 30 in the sub trim to get it centered.
So the next problem that I cant figure out, is how the steering trims are adjusted with each other between the two different channels. In the 4ws setup, I have position 0 as front wheel steer only, position 1 is 4 wheel steer, position 2 is crab steer, and position 3 is rear steer only.
Here is the frustrating part. When switching between modes, the axles want to re-enter at different positions. I then have to adjust the trim and sub trims again to get the truck to track straight, and then when I switch back to the previous mode, the trim is off again. I cant figure out what is linking the channels and why its different for each position of the D switch.
I'm going to try adding a second model to the transmitter, and re-binding the receiver again, starting with everything at 0. Once the servo centers itself after binding, I will attempt to straighten the wheels and re-attach the servo horns as close to 0 as possible.
Any suggestions?
Digger
Any suggestions?
Digger
