new2it
I'm thinking of setting up four wheel steer. Do I need two BECs, one for each servo or can I wire them both up to one BEC? Thx.
Sounds like I should run two to be safe and have a back up. Thx for the help. Now a wiring question. Do I need two open slots in the receiver or do I wire the two BECs together and use one slot? I'll try googling and see if I can fnd a diagram.
Winnerone23 - did you make the bypass or can you buy one?
I'm with Joker.. I ran 2 bec's and each had it's own bypass. That way, if one failed (which happened) I could plug the front steering into the rear steer bec and keep going.
Here we go, maybe dumb questions, but oh well. How do you wire a bypass? Could you use a 6ch rx with a 4ch tx (use a 4px)? Use the two extra channels for Bec?
Is it possible to build two bec's in one package. My only problem is where to put two bec's. I I could get it in one small package that would be awsome.
Is there a way to shrink it up some.maybe going to a pair of 5 amp bec's rather than ten amp ones. Just trying to get it as small as possible.
