fyrstormer
Around the beginning of 2017 I bought the SSD 2-speed transmission kit, but I was never happy with its performance. There was too much slop in the shifter clutch, the output shaft wobbled and flexed the entire gearbox housing, and the teeth on one of the high-speed gears weren't blunted properly so they bottomed-out in the spaces between the teeth on the other gear, causing an awful whizzing sound whenever the truck was running in high gear.
https://www.youtube.com/watch?v=ucnsOcX2nqg
I went through three SSD 2-speed kits and they all had these same problems, so eventually I gave up and the truck just sat on the shelf while I waited for the official Axial 2-speed kit.
Well, that 2-speed kit never materialized. Axial just left us hanging. That sucked. However, they did release a shift-fork that would fit the SCX10 II's gearbox housing, and the Yeti 2-speed gears are a direct fit. So eventually I got around to buying the Yeti 2-speed kit and I installed it a couple days ago.
I did end up having to use one part from the SSD 2-speed kit -- the shift-fork linkage rod. The one that comes with the Axial Yeti 2-speed kit is designed to thread into the shift-fork, but the SCX10 II compatible shift-fork just has a bare unthreaded hole. I had to grind-down one side of the shift-fork to get the SSD linkage rod to fit far enough that the E-clip could snap into its groove, but that doesn't affect the fork's ability to move far enough to shift solidly into both gears. (I checked the positions of the shifter parts before grinding to make sure I should grind all the excess material off one side, instead of grinding half-and-half off both sides.)
I was also unhappy with the narrow gear range offered by the SSD 2-speed kit, though that wasn't their fault -- the gearbox is sized to fit a 26t 48p input gear, and there isn't even a smidge of extra space for a larger gear to fit. Well, the Axial Yeti 2-speed kit came with an optional 26t 48p output gear, intended to mesh with a 28t 48p input gear, and I damn well wanted to use it because I wanted a wider gear range. With the intended setup, the truck's top speed was 5mph in low gear and 9mph in high gear, which was pretty pointless. I used the awesome power of elementary-school arithmetic to determine I could get an 11mph top speed in high gear if I could run the 28/26 optional gears instead, without having to compromise on torque in low gear by gearing-up the motor pinion. So I got out my Dremel (which I use so often I might as well just leave it out all the time), and I started grinding away plastic from the inside of the gearbox housing until the 28t input gear fit. As you can see above, it worked -- I didn't breach the side of the housing despite not having much plastic to work with in the first place.
I took this picture just before I buttoned-up the gearbox housing. You can see the 28/26 2nd-speed gears sticking out the back; the 28t gear is actually made by Hot Racing, intended as an upgrade for the sintered-metal gears used in the RTR Yeti, but it works just as well here. This way I have a complete set of hardened-steel gears in my SCX10 II's gearbox.
This setup works much better. It's quieter and the Axial output shaft spins true like it should, and as I calculated I get top speeds of 5mph and 11mph, which is on-par with my Vaterra Ascender. If there's anyone else who's looking for a better 2-speed setup and doesn't want to have to go with the older, higher center-of-gravity RC4WD AX2 transmission for the Wraith, this is a good solution.
