2.2 LCG Straight Axle Mashup Incoming
Timmahh
Mudville
Decided to pick up a Chy-na LCG chassis but one that doesn't appear to be a knockoff of others that I can tell.
At any rate, this should be a fun build.
Using the LCG Chassis set with a set of SSD Pro44s and an Axial 3gear tranny out of the Honcho, so I may mod the plastic case to accept a CF motor plate to add some good rigidity to it and keep it light weight.
have a few sets of 2.2s available for it and I can always covert the rear axle to rear steer as there will be no dig on it.
Probably go with either a set of Dravtechs or perhaps some Echo shocks.
have 324mm ss HC links in the cart from evilzon as well.
Pro44s are built pretty stock, except it does have alum chubs and brass knucks, and SSD red aluminum pumpkin covers with scale hardware.
Have a few other things I think I can use on this build around but will need to get some things for the build.
thinking of maybe staying brushed or going with an am32/revolver setup to keep it lightweight but powerful.
No idea on body choice yet. but got plenty of time for that.
should be able to start ordering some needed things over the next week or 2 but the bulk of the items will be after the start of the year as it's gonna take about 3 weeks for the lcg chassis to show up once I get it ordered next weekend.
Anyways, I'm looking forward to seeing what the cheater rig is all about.
LCG Chassis ordered and looks like near the end of Jan to get here.
Links and Treal wheels ordered (But they're 1.9s gonna get 2.2s also)
These should be here Xmas Eve or Friday.
