1:6 crawler FIRST TEST RUN
F.i.M.S presents Rc.
Colyton
Here's the first test run.
Evie, 7, is the test driver
https://youtu.be/3ojBYKF4yUs
Here's the final spec;
T6 5mm aluminium plasma cut chassis rails
- Xtraspeed full alloy axles
- Alloy shock hoops
- Epic 6 screw beadlocks with face/back alloy beadlocks ( colour coded to body )
- Austar 125mm tyres
- xmaxx 6mm thread alloy rose eye swivel ball ends
- pitman style bent custom links
- extra speed 110mm shocks
- alloy rear reverse mount 90mm shocks
- 3 piece Hotchkiss style rear semi-elliptical leaf springs w/pitman link.
- Hercules 200mm steel driveshafts
- CNC helical gearbox
- 600 Jamara motor
- alloy transfer box
- Ripmax quartz servo
Still needs some things done, tweaked & adding ( wheel wells, some other bits and bobs)
