Hello.
I wanted 1/35 scale LC70 RC car, but couldn't find. Therefore I decided to modify plastic model to RC car. Meng Model VS-004 1/35 LC 70 is modified using Orlandoo F150 kit.
At first, I considered to replace Stock front axle to F150's.
However F150's front axle is too long. I gave up front drive and replaced Differential gear box to simple 6mm plastic pipe.
Tire hub is cut to shorter.
Inserted ball bearings into hubs.
Servo is mounted on Axle. Because the stock plastic chassis is too weak against steering/vehicle impact mechanical stress.
I re-used holes on axle for 4-links & Spring dumpers for F150.
I found the modified axle is too thick to put on upper side of leaf spring.
So I mounted the mod front axle to lower side of the leaf spring.
Rear axle is also too long than stock axle. And, there isn't sufficient clearance to put it on the leaf spring.
So I cut the axle to meet the stock axle length.
Inserted plastic pipe to fit ball bearing.
Attached sliced plastic pipe to hub to fix the shaft on hub.
Cut rear shaft to fit the stock axle's length.
Made plastic blocks to fit axle to leaf spring.
Assembled the Rear Axle.
