Spence
HI guys, after some further reading on these forums, the stock diff cup screws look like garbage, they are a self tapping screw. I just read on these forums that the screws can snap and blow diff gears, as well as ring and pinion gears.
I mean my plan would be out of the box rtr, to replace the servo and servo horn, as well as installing a castle waterproof bec. Would start to run it with a 2s lipo pack.
I'm just not sure if its an immediate thing to replace the diff cups or not...
I was thinking of doing rear, and center diff upgrades with the exotek cups..
Granted I can't purchase the rock rey currently, but this time is perfect to do research before I buy or have upgrade plans.
I'm curious if this is simple as just replacing the diff screws with a regular m3 metric counter sunk bolt of the same diameter and length? Or if its worth it to get the EXOTEK diff cups.
I don't really like the exotek diff cups cause it appears that the bearing surface is aluminum as opposed to a steel bush. I'm just curious how you guys have faired with the exotek cups.
I have also seen the upgraded front driveshafts too, just a beautiful aluminum piece that bolts onto the stock outdrives, of course out of stock lol.. They should have made them from steel lol... Still look really nice and worth a buy...
Thanks
-Spence
Thanks
-Spence
