Very true on the parts. I finally after months of looking, begging an pleading have got enough parts to finish mine and have some spares. Due to the scarcity of aftermarket parts these will likely be my last ones. Shame because i read such great things about them
My Twin Force Axles
These axles seem to be gaining in popularity again and with the wealth of knowledge albeit outdated, it helped me a ton in building mine. The Driveshaft’s in CVD or Universal form are the hardest part about deciding to use these axles. One thing I hate when trying to do a mod or research info is the lack of Part Numbers or links to info. If you are going to build these axles you will more than likely be doing some research on you own. I know I did and was confused at the beginning with what worked and what didn’t. While my list is not extensive, it will help some I am sure. I don’t know it all and I am not a Twin Force Axle guru but I have lots of PN’s on items that did and did not work and links to them so if you are in need of anything just ask. This Hobby is all about sharing knowledge so ask away.
Front Axle Housing:
Standard Housing
RC4WD Aluminum Front Hub Carriers
Stock Kyosho Knuckles, FE Bearings, Bushings etc.
On Axle Servo Mount & 4-Link Fin (Thanks YotaChump)
Super Shafty ?? 4 Link Tube Mounts (Thanks YotaChump)
Custom 3/16” Drag and Tie Rod w/Revo Rod Ends (Need to Make)
All 3mm Hex hardware
Front Drivetrain:
Long Side - Kyosho Rear Center Universal Shaft (113mm) (ST-R) PN KYOIFW160 w/ Kyosho Heavy Duty Front or Rear Universal Shafts Stub Axle portion PN KYOIF482
Short Side - SWorkz S350T CVD – 86mm PN SWX-330484 **
Long Side - Losi LST XXL Axles Long and Short Side – PN LOSB3522
HPI Bullet Proof Diff Bevel Gear Set 29T/9T – PN 102692
CDW Billet Spool/Locker (Thanks YotaChump)
Axial yeti XL 17mm Hex – PN AX31255
Fast Eddy Bearings
Diffs Shimmed Correctly
** Had to open up the pin slot to accommodate the Losi 3mm Pin
Rear Axle Housing:
Standard Housing
Super Shafty Long and Short Rear Lockouts (Thanks YotaChump)
Freestyle RC Pumpkin 4-Link Mount
Freestyle RC 4 Link Tube Mounts
** Need to open up the links so i can slide them farther onto the tube.
Rear Drivetrain:
Long Side – Stock Kyosho Swing Shaft - 114mm PN KYOMA024
Short Side – Stock Kyosho Swing Shaft - 84mm PN KYOMA081
Super Shafty Locker
Kyosho 17mm Extended Hex – PN KYO33004B
Fast Eddy Bearings
** If you are going to use an axle mounted servo i would use the Rear Carriers since it lines up the old shock mount thingy in a non-clocked position. No reason other than looks IMO.
