1
2
36
35
Axial Racing releases new Bender Customs SWX Chassis Kit
AX30506 - KIT
AX30505
AX30504
AXA1413
AXA1415
AXA1416
AX30479
AXA1427
AXA1429
AX30475
AX30476
AX30477
AX30478
If your driving style prefers a narrower chassis with just the right amount of suspension travel to maintain stability on any terrain, then you will demand the Bender Customs SWX. The SWX is the 4th generation of several years of chassis research and development.
  • Narrow chassis for squeezing through tight gaps
  • The originator of the "open sided motor plate".
  • Delrin skid plate wraps under the side plates to help you slide over the rocks better
  • Skid plate has a directional channel down the center to help prevent lateral slides when on the rocks
  • Counter sunk screws help prevent hang ups
  • Thick 3mm aluminum side plates provide a rigid chassis
  • Includes grey anodized links and bolts directly to any AX10 Scorpion
  • Complete easy to follow instructions makes it easy for anyone to install and setup
  • Allows the use of most transmissions and dig units currently on the market
Part numbers and EAN Codes
Part #
EAN
Description
 List
AX30506
877493005689
Axial Bender Customs SWX Chassis Kit
 $ 120.00
AX30505 877493005696 Axial Bender Customs SWX Chassis Plates $ 50.00
AX30504 877493005702 Axial Bender Customs SW Series Skid Plate $ 28.00
AX30475 877493005672 Threaded Aluminum Pipe 6x74.5mm - Green (2pcs) $ 9.25
AX30476 877493005986 Threaded Aluminum Pipe 6x74.5mm - Red (2pcs) $ 9.25
AX30477 877493005993 Threaded Aluminum Pipe 6x74.5mm - Blue (2pcs) $ 9.25
AX30478 877493006006 Threaded Aluminum Pipe 6x74.5mm - Orange (2pcs) $ 9.25
AX30479 877493006013 Threaded Aluminum Pipe 6x74.5mm - Grey (2pcs) $ 9.25
AXA1413 877493006044 1x6mm Spacer - Grey (6pcs) $ 6.25
AXA1415 877493006068 3x6mm Spacer - Grey (6pcs) $ 6.25
AXA1416 877493006075 4x6mm Spacer - Grey (6pcs) $ 6.25
AXA1427 877493006181 7x50mm Post - Grey (2pcs) $ 6.75
AXA1429 877493006204 7x60mm Post - Grey (2pcs) $ 8.00
AXA149 877493006303 M3x20mm Hex Socket Flat Head - Black (10pcs) $ 2.50
AXA146 877493006310 M3x12mm Hex Socket Flat Head - Black (10pcs) $ 2.50
AXA896 877493003722 M3x12mm Tapping Flat Head (Black) (10pcs) $ 2.50
RCCrawler LLC
